Bengaljim54
Nov 13, 2020Aspirant
R 9000 nighthawk x 10
When I try to connect router to modem, all I get is the 60 Hz light lights up and does not connect to internet.
Nov 13, 2020Guru - Experienced User
what modem/gateway do you have?
What firmware is on the router?
Are you able to access/use the router hardwired in?
What happened to cause this? Were you rebooting/resetting/moving or did it randomly die?
Did the wifi on/off button get hit? (push and hold it for 2 seconds)
