Bengaljim54
Nov 13, 2020Aspirant
R 9000 nighthawk x 10
When I try to connect router to modem, all I get is the 60 Hz light lights up and does not connect to internet.
PauLita
Nov 13, 2020Luminary
Try to connect modem directly to PC.
Bengaljim54
Nov 18, 2020Aspirant
I'm not that great at computer stuff. So I connect my laptop from the modem by my wifi. Then plug modem to router then go to counterpoint. I bought this supposedly refurbished. So I'm think I have software error. So any suggestions I will be grateful.
- plemansNov 18, 2020Guru - Experienced User
It goes:
Modem----->router------>PC/devices
What modem do you have?
What firmware is on the router?
- Bengaljim54Nov 27, 2020Aspirant
Arris CM80A. I'm not sure what firmware is on it. Don't know how to check? Pretty much a rookie in computer and networking
- plemansNov 28, 2020Guru - Experienced User
I googled the Arris CM80A. And couldn't find one. The top result was actually this post. Are you sure thats your modem?
The firmware is which version is on the R90000.
Is this a new purchase?
- Bengaljim54Nov 29, 2020Aspirant
I have an Arris cm 80 a
- plemansNov 29, 2020Guru - Experienced User
Maybe you mean CM820A?
if not, google the cm80a. tell me what you find.
