fluesprekker
Dec 06, 2021Aspirant
R6020 blocking access to certain websites
Hi. I am getting "This site can’t be reached" <website> took too long to respond. errors, only on certain Russian websites. If I plug my network cable directly into my modem, thereby bypassin...
Dec 06, 2021Guru - Experienced User
Netgear has set up a community forum specifically for General Router products. Most of the people who watch that forum are more likely to have experience with older routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Try a factory reset on the router and setup from scratch.
Be sure your not in a double NAT condtion with a router in front of the 6020 router.
Thank you
