BILL395163
Apr 26, 2021Follower
R6020
I was able to connect my R6020 router (using the SSID & Password on the label) to my existing ZyXEL C1100Z CenturyLink Modem/Router via the LAN port. The router is immediately recognized, the pas...
microchip8
Apr 26, 2021Master
Don't use crappy apps to configure a router. Try http://routerlogin.net or http://192.168.1.1 in a browser. If the IP doesn't work, you can try http://10.0.0.1
