neelgpatel20
Mar 25, 2021Aspirant
R6080 DNS Update 403 Forbidden
Hello, I have R6080 l AC1000 Dual Band WiFi Router from Netgear I am trying to change DNS setting but I am getting an error 403 Forbidden. I try to reset, download latest version of framework form ne...
neelgpatel20
Mar 26, 2021Aspirant
I have latest freamework install on netgear router but still i can't change setting
antinode
Mar 26, 2021Guru
> I have latest freamework install on netgear router [...]
Says who?
> https://community.netgear.com/t5/x/x/m-p/1966527
Read it again?
- HJTeixMay 05, 2021Guide
Simply disconnect the modem cable from the router and you can save whatever you want.
- GROOVYJOSHCLARKOct 11, 2021Aspirant
Bingo, thanks! That was the issue for me too, it would forbidden with ISP connected (internet), but once I simply pulled internet, it would save and worked!!
- HJTeixOct 16, 2021Guide
I and many people need a new firmware to fix the 403 forbidden error problem!!
The new 1.0.0.52 not solve the problem and disconnecting the cable not works anymore! In 1.0.0.48 it still works but there is another problem!
Model: R6080|AC1000 Dual Band WiFi Router
