Gru_11
Nov 16, 2020Aspirant
R6080 Internet disconnects for complete night
From the past one week, The internet link in the router disappears post 12 midnight. Internet gets cut off. Contacted ISP, they have confirmed that there is not issue from there end as rest of the com...
Nov 17, 2020Guru - Experienced User
What modem/gateway is it connected to?
What firmware is on it?
is it at exact times? LIke there's been a schedule setup?
Gru_11
Nov 17, 2020Aspirant
It’s directly connected to the LAN, no modem is connected. From the past few I am facing the issue. Post 12 am the net get disconnects automatically probably till 8am.
- plemansNov 18, 2020Guru - Experienced User
And that lan is connected to something. If that's whats disconnecting, so with the router
- Gru_11Nov 18, 2020AspirantLAN is connected to router.
- Gru_11Nov 18, 2020AspirantPlease someone help me...
where does the cable come from that is plugged into the wan port?
What gateway, ont, whatever is on the other end?
Have you checked with your isp?
have you tried factory resetting the router?
