Zombiepunch84
Feb 16, 2021Aspirant
R6080 took a crap during update
So when I was updating the firmware the other day it was almost done and my Internet went down so netgear basically has been flashing 2 lights it's the power symbol and the 3 dot symbol and I can't ge...
- Feb 16, 2021
had issues with that as well..said screw it and got another one!
benthekul
Feb 16, 2021Guide
Via a wired connection, you'll have to put a firmware on the router. Assuming that there isn't any firmware on it. And you can do that by using a TFTP client. Attached is a link to a Netgear article discussing this:
https://kb.netgear.com/19841/Reinstall-the-firmware-on-a-router-without-the-setup-CD-recovery-tool
