nround
Mar 21, 2021Follower
R6080
Are there instructions for setting up my R6080 as a second router?
antinode
Mar 22, 2021Guru
> [...] Are there instructions for setting up my R6080 as a second
> router?
That might depend on exactly what "as a second router" means to you.
"second" to what? Why? One possibility:
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Use the Router as a WiFi Access Point Only".
