Dervy
Nov 05, 2020Aspirant
R6120 - QoS settings not showing
Hi everyone, I'm having troubles finding the QoS setting on the router Web interface. Anyone knows what's up with that? Cheers
Nov 05, 2020Guru - Experienced User
I don't have a R6120 so I can only go off the manual and spec sheet. But it doesn't look like I can find any qos services.
It could be because the R6120 is a base model AC device.
- DervyNov 06, 2020AspirantIt could be indeed.
Do you guys have access to this QoS link through nighthawk UI?
