MrMajorThorburn's avatar
Mar 06, 2019
R6120 AC 1200 tc_exist_unit_hijack.htm
Wifi router setup and connecting from my laptop it states internet access but I dont get any url resolution. Using Netgear Genie I can see the network ok. Right mouse select the router and then s...
  • MrMajorThorburn's avatar
    MrMajorThorburn
    Mar 06, 2019
    OK, another attempt.
    Did a reset to factory settings. Same problem.
    Did another power off. Left off for 30 minutes. Powered on and
    woopee
    I got the proper initial administartion screen Im was expecting.
    Security settings changed and firmware update completed.
    I have no idea why this error came up and why it showed in such a strange manner.
    I consider this topic completed.
