cgilz24's avatar
cgilz24
R6120 Intermittent internet outages - multiple times/day
Modem = Netgear CM400   Purchased the router and modem together about 3 months ago.   About a month ago, the internet started going down once or twice a day.  When I would go check them, the inte...
  • cgilz24's avatar
    cgilz24
    Aug 29, 2019
    YES... T3 and Criticals all over the place.  I contacted Comcast (in India, of course) and they said something along the lines of there being boot timeouts in the modem logs and they would perform maintenance to remove and reboot and resync.
    For about an hour, no problem.  Then some more modem issues...which is a Netgear CM400 by the way...arose and I did another round of chats with persons whose names I can't even begin to pronounce...let alone spell.  Nonetheless, it seems to be working now, and the router has only gone orange on the internet light once for about 30 seconds.
    By the way, I completely reset the modem twice, deleted and downloaded the Nighthawk app twice.  So, started out with fresh installs twice.  Seems to be working so far...time will tell.
