Hammerhead111
Jan 14, 2022Follower
R6120 Nighthawk router
Have contacted Netgear Tech Support re. R6120 router and was told by one person that this router download limit is less than 90 Mps. My input internet speed is 400 Mps, yet I cannot get even 25% out...
DexterJB
Jan 30, 2022NETGEAR Moderator
Hi Hammerhead111, the R6120 is equipped with Fast Ethernet LAN ports which means it supports 10/100 connections. We recommend going for a higher model to support your ISPs 400Mbps connection.
Dexter
