Trokkedet
Jun 11, 2021Follower
R6220 as bridge
Since it seems like noone is able to answer this in a concrete way, I'm close to throw this piece of xx out the window right away, but let me give it one last chance. Setting: I have a wifi route...
antinode
Jun 11, 2021Guru
Huh? Who was asked what?
> [...] The R6220 is supposed to be able to operate as a bridge.
Who supposes that? What, exactly, does "as a bridge" mean to you?
> All instructions I've found [...]
Where, exactly, did you find what, exactly?
> This is how simple it is to configure a competitor: [...]
A TP-Link RE200 or RE210 is a wireless extender, not a router (like
an R6220). Yes, configuring a wireless extender as a wireless extender
might be easier than configuring a router as a wireless extender.
Especially if that router does not support operation as a wireless
extender.
Netgear makes wireless extenders, too.
> [...] I have to do these steps: [...]
You omitted the most important step:
0) Get a device which was intended to do the job you want done.
> [...] I've found answers like: "The R6220 doesn't have that feature"
I'm less amazed by that than you seem to be.
