anilsaxena
Jun 05, 2021Aspirant
R6220 blocking some websites
My Netgear R6220 started blocking some website since last 1 week, I have resetted the router, tried direct ISP connection and it worked fine. I have also tried from other devices and same websites ar...
Jun 05, 2021Guru - Experienced User
1. what actual modem/gateway is it connected to?
2. what actual firmware number are you on (don't say the latest. it might not be and it changes if people in the future are looking at this for help)
3. What actual notice are you getting when they don't work?
4. have you tried using a different dns like googles at 8.8.8.8 or 8.8.4.4 or cloudfare at 1.1.1.1
- anilsaxenaJun 05, 2021Aspirant
Thanks for the response.
It is PPP0E connection with ISP Line directly connected to this router.
V1.1.0.106_1.0.1
I am just getting "The connection has timed out"
Yes, tried with Google dnsand ISP dns.
- plemansJun 05, 2021Guru - Experienced User
and somethings on the end of the pppoe setup.
what is it?
- anilsaxenaJun 05, 2021AspirantIt is controlled by ISP, I don’t know what setup they have. But if I connect computer directly with dial up setup then it works alright.
