anilsaxena
Jun 05, 2021Aspirant
R6220 blocking some websites
My Netgear R6220 started blocking some website since last 1 week, I have resetted the router, tried direct ISP connection and it worked fine. I have also tried from other devices and same websites ar...
antinode
Jun 09, 2021Guru
> [...] I have tried same ISP with different router, [...]
I'm not claiming that the R6220 is innocent, only that
"atlassian.com" might look different because of DNS differences.
Clearly, my (Google's) stuff didn't resolve it the way yours did.
If you're doing anything with IPv6, which I'm not (so far as I know),
then that's another place where one router might do something
differently from another. But none of that means that the R6220 is
"blocking" anything.
anilsaxena
Jun 09, 2021Aspirant
Strange thing is it started happening only in last 10 days or so. Although things working well on other router, I won't rule out something going at ISP level.
I have tried all settings for IP6.
