ParasWadher
Mar 26, 2020Initiate
R6220 bricked after latest hotfix R6220-V1.1.0.92_1.0.1_BETA
Hello all, firstly have gone through all the solutions provided in the forum regarding bricked r6220 but nothing is working for me. TFTP2.exe - not working. TFTPD64.exe - not working NMRPFLASH ...
- Mar 26, 2020
Problem is solveD in macOS (nmrpflash).
I dont know why i had issues in Ubuntu linux as well as in Windows 10, even after installing npcap and other linux lib.
How i solved :
1 > set manual ip to 192.168.1.10 and default gateway to 192.168.1.1
2> open termial , set sudo su and download binary for nmrpflash.
3>downloaded stable firmware 1.1.0.86 from netgear.
4>copied all files to a folder CC in home directory
5> connect ethernet cable and power adater to router and pc (but dont turn on router)
6> run usin X/nmrpflash -i en -f /Users/Paras/CC/r6220.img
7> now quickly turn on the router
Volila ! Problem solved .
Hope this helps you ALL.
ParasWadher
How i solved :
