firoz3321
Nov 16, 2021Guide
R6220 Router gigabit ethernet supported ?
I have been using the Netgear R6220 router. Recently i upgraded my internet speed from 75mbps to 125mbps. But the max speed never crosses 80~90 mbps. The service provider said the router doe...
- Nov 16, 2021
I'd take it up with your ISP. Tell them its a gigabit router but only connecting to 10/100mbps.
Its not something that you can change as its auto-negotiates.
If you can't change out the cable, then they can test it.
If you could directly connect your pc to have it work, then you could test it.
Nov 16, 2021Guru - Experienced User
the router is gigabit.
What modem is it connected to?
What speeds do you get from the modem?
Have you tried replacing the cables from modem--router and router----device?
Make sure you test hardwired.
