firoz3321
Nov 16, 2021Guide
R6220 Router gigabit ethernet supported ?
I have been using the Netgear R6220 router. Recently i upgraded my internet speed from 75mbps to 125mbps. But the max speed never crosses 80~90 mbps. The service provider said the router doe...
- Nov 16, 2021
I'd take it up with your ISP. Tell them its a gigabit router but only connecting to 10/100mbps.
Its not something that you can change as its auto-negotiates.
If you can't change out the cable, then they can test it.
If you could directly connect your pc to have it work, then you could test it.
Nov 16, 2021Guru - Experienced User
the router is gigabit.
What modem is it connected to?
What speeds do you get from the modem?
Have you tried replacing the cables from modem--router and router----device?
Make sure you test hardwired.
firoz3321
Nov 16, 2021Guide
Hi thank you for the confirmation regarding gigabit support.
There is no modem connection, an ethernet cable is provided by the ISP directly.
PPPoE connection. The ISP says others are able to get 125mbps speeds so it must be the router issue.
