nstuckey88
Jan 03, 2022Follower
R6220 Router Mesh Compatible
I haven't been able to find anything stating this one way or another but wondering if the R6220 router is compatible with a mesh network? Having some connection issues in my house and looking int...
Jan 04, 2022Guru - Experienced User
Are you wanting a full mesh system or just wanting a little more coverage?
If you're looking at just adding some coverage, you can add a mesh extender.
If you're needing more than 1 extender, I'd recommend moving to a full mesh system but if you're only needing the one, it is a decent option?
