MichalBan23
Dec 31, 2021Follower
R6220
The R6220 model does not work in page filtering. I entered the addresses of sites to be blocked in the wifi network, but it did not work, still working. How to set it up?
Netgear has set up a community forum specifically for General Router products. Most of the people who watch that forum are more likely to have experience with older routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Thank you - michaelkenwardGuru - Experienced User
Your question applies to just about every router, so heaven only knows why you were told to go somewhere else, without offering even a little bit of help.
Repeating your message there will not only get fewer readers, but will also baffle anyone who does read it because you don't provide much in the way of detail.
What are you doing and where does it go wrong.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
