tonyd1947
Jul 16, 2021Aspirant
r6230 lan to wan installation help
Hi everyone...I am going to install an r6230 in a lan to wan configuration with the r6230 being the secondary router and the primary is a linksys wrt1900ac. I need help with configuring both routers...
- Jul 16, 2021
ok this isn't my original concern, but more answers invite more questions. I'm accepting your answer as the solution. Thanks again for spending this time with me.
antinode
Jul 16, 2021Guru
> [...] it's assigned but i can't tell if it is being used. [...]
I don't know why it would be used. My guess would be that Windows
(these days) configures it by default; if you need it, it's there.
If I really wanted to know, then I might run the experiment, and
disable IPv6 on that interface. If nothing stops working, then it
couldn't be very important.
tonyd1947
