ktb94
Dec 12, 2020Aspirant
R6230 Slow Wireless Speed (Download at half speed and Upload at a third the speed)
Current Router Firmware Version: V1.1.0.104_1.0.1 (this is the newest version) I have Verizon Fios and my speeds at 300/300 Mbps (download/upload). I have tested the speed by direct connecting to...
Dec 12, 2020Guru - Experienced User
What verizon gateway do you have?
What device are you speedtesting with?
What speeds do you get hardwired into the router? Not wireless
Many things impact wireless from the home you're in, the device you're resting on, the interference in the area, etc. And you should have realistic expectations of what a AC1200 router can do. Here's testing under optimal conditions:
The manual walks you through disabling those services.
https://www.netgear.com/support/product/R6230.aspx
In terms of the scanning, you can use something line inssider or acrylic wifi scanner. I use them frequently
- ktb94Dec 12, 2020Aspirant
I checked all the settings and all the things you said to disable are already off.
- plemansDec 13, 2020Guru - Experienced User
You can try downgrading the firmware a version or 2.
If you do so, do it over a hardwired connection, factory reset afterwards, and do a clean install (not from a backup).
Its worth a shot but again, I wouldn't have much expectations from a AC1200 router.
