ktb94
Dec 12, 2020Aspirant
R6230 Slow Wireless Speed (Download at half speed and Upload at a third the speed)
Current Router Firmware Version: V1.1.0.104_1.0.1 (this is the newest version) I have Verizon Fios and my speeds at 300/300 Mbps (download/upload). I have tested the speed by direct connecting to...
Dec 12, 2020Guru - Experienced User
The manual walks you through disabling those services.
https://www.netgear.com/support/product/R6230.aspx
In terms of the scanning, you can use something line inssider or acrylic wifi scanner. I use them frequently
ktb94
I checked all the settings and all the things you said to disable are already off.
