Sasquatch3000
Jul 15, 2021Aspirant
R6260 <10Mb on 100Mb Charter/Spectrum service
Our R6260 was working great at first. We have Charter/Spectrum 100Mb service on a Charter provided Arris TM1602 cable modem. Slow past month,at 10Mb. Tried resetting and redoing entire setup on R6260...
Sasquatch3000
Additional information:
- I connected directly to the cable modem, and was getting 90 to maybe 95 Mb speeds on Ookla speed test.
- I connect by wire to the Netgear R6260, and it is also slow, so it is not just the Wifi on this device.
Question:
I have not seen a firmware update in maybe a couple months. Please don't tell me this model is already out of date. I know I've had other devices that have had updates lasting many YEARS!
Thank you.
Jul 16, 2021Guru - Experienced User
1. what actual firmware are you on?
2. did you try a factory reset and reinstall?
3. the R6260 is a base model device. You're not going to get the same amount/frequency of updates as you do from a flag ship router.
- Sasquatch3000Jul 16, 2021Aspirant
Firmware Version 1.1.0.78
- plemansJul 16, 2021Guru - Experienced User
Did you try a factory reset?
I rebooted the thing while holding in the little reset button in back with a paperclip. Is that what you mean?
