huseyine
Oct 18, 2020Initiate
R6260 bridge mode
Hello all. I have a virgin superhub 3 which is good but i want to spread wifi signal evenly across house. I know i could buy range extenders but i have a 2nd wifi router. Can i use this in bridge mode...
- Oct 20, 2020
Bridge mode isn't repeater/extender mode.
It'd simply connect the R6260 to the primary router and let you use the ethernet ports.You'd be better to hardwired in the r6260 and run it in ap (access point) mode.
Oct 20, 2020Guru - Experienced User
huseyine
Oct 21, 2020Initiate
Thank you. Clarifies all for me.
