Dbanyayd
Sep 14, 2020Aspirant
R6260 configuration as remote wireless access point
R6260 This is a brand new router. Please advise procedure to to set it up and to configure it to become a remote wireless access point connected to the main broadband access router by ethernet cable....
- Sep 14, 2020
the install guides and manuals go over this. They can be found here: https://www.netgear.com/support/product/R6260.aspx
Sep 14, 2020Guru - Experienced User
Dbanyayd
Sep 22, 2020Aspirant
Thanks,
I had already downloaded the manual and missed the relevant section when I skipped through the index. Your reply forced me to look again. R6260 now working fine as remote access
