bjdoty
Jan 03, 2021Aspirant
R6260 devices can't get up after power cycle
Every time power goes off and on devices say can't get up and won't connect. I have 25 devices. I have to do a factory reset to fix it. Works until the next power cycle them have to reset again.
michaelkenward
Jan 04, 2021Guru - Experienced User
I have seen this before. It has nothing to do with the firmware, and I don't need a "factory reset".
What happens is that the modem takes so long to boot that the router times out before it can reestablish a link to Internet through the modem.
Next time this happens, don't reset, try this:
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
bjdoty
Jan 04, 2021Aspirant
That is great, but my issue is my cameras. If I'm on vacation and power goes out and on, I can't connect to view my cameras. Have to wait until I get home to reset. Would I have this problem with a newer router maybe the ac2600?
- plemansJan 04, 2021Guru - Experienced User
Or you could try getting a backup power supply so when the power does go it, it doesn't for the modem and the router.
- michaelkenwardJan 04, 2021Guru - Experienced User
bjdoty wrote:
That is great, but my issue is my cameras.First I would check that this is the issue. Should be easy enough to experiment while you are there to see what happens.
If so, look for solutions.
As plemans says, it may be UPS, especially if you live somewhere that loses electricity often.
It may be a better modem. (You don't say what you own.) In my case I swapped out a DSL modem/router (D6400) in modem only mode in favour of a standalone modem (DM200).
bjdoty wrote:
Would I have this problem with a newer router maybe the ac2600?Who knows?The R6260 is pretty basic in Netgear terms.
But ac2600 isn't a router. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
- bjdotyJan 04, 2021AspirantI have R6080 and R6260. I reset both to factory defaults, then set up only changing the ssid and password. If I power cycle the 6080, everything comes back up no problems. I have 25 devices, cameras, smart plugs, tvs, speakers, computers. Now if I cycle power to the 6260, my phone keeps saying can't get ip and my cameras are flashing led which means not connected. Sometimes my roku will connect though, but not all devices. I tried unplugging the modem and router and then starting the modern first, but that doesn't work. I started noticing problems after I updated to latest firmware couple weeks ago. Also if I log in to router it is red and says not connected to internet, but it always shows that even when it's working. Before the firmware update, I think it says good in green letters. I have cm400 modem. My old 6080 works great but it's only 100 speed and my modem is 1000. I can shut the whole house off and everything comes back up fine. I need the faster router though so I may just buy a new one. Note I also put old firmware back in 6260 and had same problems. I plan on getting more devices too so a new one may be best.
bjdoty wrote:
I have R6080 and R6260.If you are running both on the same network, no wonder you have problems.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
But I am getting hopelessly confused here. (Easily done.) A steady drip of new details doesn't help.
bjdoty wrote:
Now if I cycle power to the 6260, my phone keeps saying can't get ip and my cameras are flashing led which means not connected.I cannot see how that relates to power cuts. But I am lost as to what is going on here.
