bjdoty
Jan 03, 2021Aspirant
R6260 devices can't get up after power cycle
Every time power goes off and on devices say can't get up and won't connect. I have 25 devices. I have to do a factory reset to fix it. Works until the next power cycle them have to reset again.
bjdoty
Jan 04, 2021Aspirant
That is great, but my issue is my cameras. If I'm on vacation and power goes out and on, I can't connect to view my cameras. Have to wait until I get home to reset. Would I have this problem with a newer router maybe the ac2600?
Jan 04, 2021Guru - Experienced User
Or you could try getting a backup power supply so when the power does go it, it doesn't for the modem and the router.
