h2005
Jan 28, 2021Aspirant
R6260 port forwarding/virtual server
Hi
I'm using a Billion router which has virtual servers set up, as shown in the attached image.
Is this something I can achieve with the Netgear R6260 router? Presumably I can also set static IP addresses for these devices through the router's control panel?
The manual seems to suggest these things are possible but it's not 100% clear, so I want to be sure before investing in the router.
Thanks.
