mdj1973
Dec 18, 2021Aspirant
R6260 router updated firmware - NAS invisible
I updated by Netgear Router firmware to version V1.1.0.84_1.0.1. After this update, my QNAP TS-253A NAS became completely invisible to the router. While it's connected with an ethernet cable, it's no...
Dec 18, 2021Guru - Experienced User
Are you looking through the app or have you logged in through the browser and checked?
mdj1973
Hi,
I logged in through the browser. I reverted back to the older version (V1.1.0.78_1.0.1), which brought the NAS back in the list of Attached Devices. While not a great solution, I guess this'll have to do for now...
- michaelkenwardDec 19, 2021Guru - Experienced User
Did you try the usual trick of rebooting the NAS?
- mdj1973Dec 19, 2021Aspirant
Yes, tried rebooting the NAS multiple times, tried turning on/off the router, without any result.
Thought so. I only mentioned it because I find that ReadySHARE has a habit of losing things until I unplug and reconnect. But that's USB. Ethernet NAS seems to survive firmware updates.
Sadly, "attached devices" seems to be an area where Netgear needs to pay some attention. New firmware has a habit of breaking it. Maybe it has done the same thing to the NAS support.
