Matias381's avatar
Matias381
Follower
Feb 23, 2021
R6260
i just i update it yesterday and my led light just blinking only the on led lights,idk what to do try to reset it,i took every cable out still i cant get router to connect my internet.cant use my wifi plz sum one helpme
1 Reply
  • plemans's avatar
    Is it the power led blinking?
    What color is it blinking?
    What firmware did you install? (version, not "the latest")
    how did you attempt the install? using the app? over wifi? Hardwired?
    Did you try a factory reset? (push and hold reset for 7-15 seconds while its powered on)
