bigmoefosho
Aug 27, 2021Follower
r6300v2 smart wifi router
so i have a wireless verizon mifi for my internet at home which does not have any ethernet ports so i got a netgear router to be able to run my dvr camera system off the router but i cant seem to get...
robjak
Aug 27, 2021Luminary
Bridge mode could be a possible way to make this work. See: https://kb.netgear.com/20831/How-to-set-up-Bridge-mode-on-R6300-R6250-R6200
It may not work with your mifi. It was my understanding that it might only work with 2 routers of the same manufacturer. But that was years ago.
- michaelkenwardAug 28, 2021Guru - Experienced User
If the wireless verizon mifi is a router – it isn't something I have encounted – then an alternative to bridge (repeater) mode could be to use the r6300v2 as a wireless access point (AP).
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Wireless Access Point (AP).
