Bluewolf21
Dec 24, 2020Initiate
R6350 bricked after update
A few days ago I tried updating to R6350_V1.1.0.78_1.0.1 with the nighthawk app. (Yes, I found out that updating through the app is not a good idea) Now the router boots up and the power and usb ligh...
- Dec 24, 2020
TFTP is sensitive to timing. try it a few times. Also, try watching an instructional video. it can help.
If it doesnt work, you can try nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Dec 24, 2020Guru - Experienced User
Bluewolf21
Jan 02, 2021Initiate
nmrpflash worked! thank you so much
- plemansJan 03, 2021Guru - Experienced User
glad it worked!
