Linconanna
Jun 01, 2021Aspirant
R6350 choppy/laggy
when I screen mirror a video or live streaming from any of my apple devices, to my Apple TV, it's choppy and laggy. The people at Target told me to disable my firewall. But that sounds risky. I ha...
Jun 02, 2021Guru - Experienced User
1. Caps lock. Please use it. It makes things easier to read.
2. what surfboard modem is it?
3. Make sure youd devices with 5ghz, are on the the 5ghz. its a much faster band and suffers from less interference.
4. Is it only on the sony tv that you screen mirror on? what sony tv is it? is it hardwired in? connected to 2.4ghz? connected to 5ghz?
5. are the videos your mirror stored in the cloud, on the device you're using?
Linconanna
Jun 02, 2021Aspirant
2. what surfboard modem is it? SB8200
3. Make sure youd devices with 5ghz, are on the the 5ghz. its a much faster band and suffers from less interference. I WILL DOUBLE CHECK THAT.
4. Is it only on the sony tv that you screen mirror on? YES
what sony tv is it? XBR55X900F
is it hardwired in? YES connected to 2.4ghz? connected to 5ghz?
5. are the videos your mirror stored in the cloud, on the device you're using? BOTH
FYI - WHEN OTHER PEOPLE TRY TO SCREEN MIRROR TO MY TV IT DOES THE SAME THING. WHEN I SCREEN MIRRORED TO A FRIEND'S APPLE TV, IT WORKED JUST FINE.
- plemansJun 02, 2021Guru - Experienced User
2. comparing using screen mirror to apple tv's version isn't the same.
3. does your friends device have issues screen mirroring on yours
4. If you connect the apple tv to your tv, does it have issues.
trying to figure out if its a networking issue or a tv issue
- LinconannaJun 02, 2021Aspirant
2. comparing using screen mirror to apple tv's version isn't the same. I'M NOT SURE WHAT YOU MEAN BY THIS
3. does your friends device have issues screen mirroring on yours YES
4. If you connect the apple tv to your tv, does it have issues. YES
Seriously. Caps lock. Its my pet peeve. Use it.
The sony only has issues with screen mirroring?
You've hooked up his apple tv to the sony via hdmi and the apple tv then had flickering?
