ileaptintoit
Nov 15, 2021Follower
R6350 I Cant download the TFTP2 file
I corrupted the firmware of my AC1750 and Im trying to upload the updated firmware using the TFTP2.EXE file but i cant download it, https://www.shadowsoftware.net/shadowgameworld/downloads/ this link...
- Nov 15, 2021
ileaptintoit wrote:
I even tried on microsoft edge just in case it was google but that didnt do anything and I cant find any information on this.
is there any other way I can get TFTP2
You probably don't need to get any TFTP clients. It is built into modern operating systems. You just have to enable it.
Read the article on using TFTP and follow the instructions to enable TFTP in your operating system.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
Nov 15, 2021Guru - Experienced User
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
