ASDF12345
Jun 25, 2021Follower
R6350 Not Connecting to Spectrum Internet
I just had my spectrum modem set up, and it is connected just fine to the internet. Power is on, internet is on, my laptop connects fine via ethernet connection. However my nighthawk R6350 route...
michaelkenward
Jun 27, 2021Guru - Experienced User
However my nighthawk R6350 router when plugged in via the same ethernet cord is not able to connect to the internet. Spectrum support was able to confirm internet is fine on their end, and confirmed by me by using my laptop.
Sounds like you may need to take the R6350 through the setup process.
Manuals are always a good place to start. Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Begin with the Quick Start/Installation Guide.
That pushes you into using the Nighthawk app. This is a dumbed down routine that is less flexible than it should be. The manual might be more useful. Or read this:
How do I install my NETGEAR router using the router web interface? | Answer | NETGEAR Support
Be careful to do things in the right order. This is important.
There may also be some helpful videos on what to do.
