GeneralTortilla
Nov 11, 2019Tutor
R6350 router keeps dropping traffic on specific games
It happens whenever I play games like Left 4 Dead and Super Smash Brothers Ultimate. The connection drops for a second, but relaunching the application fixes it. When playing Left 4 Dead, I can't joi...
- Nov 12, 2019
Maybe those games need an open nat to function. Not sure as I'm not a gamer.
https://kb.netgear.com/23020/Opening-ports-for-internet-games-and-applications-on-NETGEAR-routers
Nov 12, 2019Guru - Experienced User
1. What modem are you using? (model number)
2. What firmware is on your router?
3. How are you connect to the router? Wireless/wired. If its wireless, what wireless adapter are you using and what radio are you using (2.4ghz/5ghz)
4. Are any other games having this issue or just that specific ones?
5. any other devices having this issue?
GeneralTortilla
Nov 12, 2019Tutor
1. R6350
2. Auto updates are on, so the latest one
3. Wired. I'm also connected wirelessly on my switch, with the same issue. (5ghz)
4. From what I can see, it's just left 4 dead and Super Smash Brothers Ultimate. Sometimes I get issues with Starcraft 2, but not consistently.
5. Just my Nintendo Switch and my Windows 10 PC.
- plemansNov 12, 2019Guru - Experienced User
Modem you're using?
- GeneralTortillaNov 12, 2019Tutor
Spectrum / Charter Communications. I'm not sure which one specifically, but it was provided by them.
GeneralTortilla wrote:Spectrum / Charter Communications. I'm not sure which one specifically, but it was provided by them.
Really doesn't tell me much. Reason why I ask is some of those units have built in routing function. if it does, it can cause a double nat which can cause issues with gaming.
https://kb.netgear.com/30186/What-is-Double-NAT
And a firmware number helps more than "the latest". you'd be surprised at how frequently people aren't "on the latest" or the app doesn't show the latest update. Plus for the people who use this is the future, they have a reference for which firmware you're on.
This would be the forum for the R6350. not the nighthawk forum.
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
