javidr
Jul 07, 2020Aspirant
R6400 - firmware update?
Hi R6400 is affected by the latest vulnerabilities affecting mergers routers https://kb.netgear.com/000061982/Security-Advisory-for-Multiple-Vulnerabilities-on-Some-Routers-Mobile-Routers-Modems-Gate...
- Jul 08, 2020
It's on that webpage that you showed in your post. It was added today.
michaelkenward
Jul 08, 2020Guru - Experienced User
javidr wrote:
However there is no firmware update for this model to patch this vulnerability
Where are you looking? There is a new firmware hotfix.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
It will also have any firmware and drivers for your device.
Look for the model number on the label on the device.
r6700v1
Jul 08, 2020Apprentice
- michaelkenwardJul 08, 2020Guru - Experienced User
Those early firmware releases will not show in the "app" interface or even in the browser graphical user interface.
New firmware usually ends up on the support pages before it hits the update server.
That's why it is a good idea to check them for your devices.
