radgear
Dec 27, 2020Aspirant
R6400 AC1750 Router dropping signal and EVEN hard wired does not connect - ISP is FINE
I have a R6400 AC1750 and is not even 4 years old and since October has been dropping signals intermittently. Then after replacing and testing with TP Link everything was working fine. Went back to t...
Dec 27, 2020Guru - Experienced User
What modem/gateway do you have?
What firmware is on your router?
The router is 4 years old and you were talking to support? support costs $ after 90 days.
radgear
Are you suggesting a new modem?
Makes no sense, the TP Link works fine without changing modem.
It's bad NG device or their firmware. Many other people reporting same signal dropping after year of being fine..
No support, no more purchases
