Toadmanor
Dec 31, 2020Aspirant
R6400 Connection Issue
Hello. I have a R6400 router that works just great with one new and frustrating exception. I have a swimming pool that has a Goldline Aqualink device. This device, previously, allowed me to access th...
Toadmanor
Jan 19, 2021Aspirant
I am trying to pu the modem inmodem mode only. I can log in to the Ubee but when I click on advanced->administration tab i do not see anywhere to put it in only modem mode.
Toadmanor
I found an area in the UBEE to disable the radio for both 2.4 and 5ghz But am still receiving the lost link error.
- plemansJan 19, 2021Guru - Experienced User
Disabling 2.4ghz and 5ghz doesn't disable the ubee's router functions. It just shuts off the wifi.
you can try putting the router in access point mode.
- ToadmanorJan 19, 2021Aspirant
Router is in access point more but still receive "lost link" error.
- plemansJan 19, 2021Guru - Experienced UserIf the R6400 is in access point mode, the ubee is controlling everything else. that's all routed to the ubee . It means the ubee is whats blocking the connection.
Well, I guess it just will not work for me anymore.
DAMN!
- plemansJan 20, 2021Guru - Experienced User
Try changing the dns server in the ubee.
Or you can contact your ISP for help putting the Ubee in bridge/modem only mode.
- michaelkenwardJan 20, 2021Guru - Experienced User
This explans what happens in AP mode:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
