pomopodo
Oct 11, 2021Follower
R6400 dns problem
i think i have a problem with my R6400 firmware. every time I try to open any page it gives me a dns problem. can you help me solve this problem thanks?
Oct 11, 2021Guru - Experienced User
Try downgrading the firmware a version or 2. the latest round of updates caused dns issues.
So download the older firmware and install it using the manual firmware update process.
- michaelkenwardOct 12, 2021Guru - Experienced User
If that doesn't work., it might help to tell people what this "dns problem" problem is.
