lnbbrady
Oct 16, 2021Tutor
r6400 gets error message "trouble finding site"
Setup Home network on satellite connection through a modem Netgear AC1750 smart wi-fi router (model r6400) Firmware version V1.0.1.74_1.0.48 Settings are set on auto-update, so I don’t know if a...
- Oct 16, 2021
Thanks for your help. I'm heading to the correct forum to post the problem right now. And I am now smarter, knowing what ONT means. Now if I only had a reason to use the knowledge. Being in a rural area, I know what fiber is, but can only wish for the speed it provides. Heck, I'd be happy to get plain old-fashioned cable service. The digital divide does indeed exist. I'm doing good to be able to use satellite service, slow as it is.
lnbbrady
Oct 16, 2021Tutor
I will repost as soon as I find the mfg/ model # of my modem. What is the ONT? Obviously I am not a hardware geek, but I follow instructions well. To enhance my learning, why should I go to the mobile routers/hotspots forum? My R6400 is plugged into my wall and into the modem that hooks to my satellite (obviously not too mobile!)
Oct 16, 2021Guru - Experienced User
Optical Network Terminal, seen on most Fiber ISP serivces.
Sorry, I posted wrong link, my bad:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
- lnbbradyOct 16, 2021Tutor
