Duffyr
Oct 17, 2021Follower
R6400 no 5g or 2.4 lights off
Need help my lights are off but the modem is good and the internet light is blinking just the 5g and 2 4 lights are off and I can not find it in my wifi list on any device
- KitsapMaster
You have managed to manually turn off the Wi-Fi radios. Neither firmware updates or reset to firmware default settings or cycling the power will change the state of the on/off switch. Once turned off, it stays off until manually turned back on.
When looking from the front of the router, the last two leds on the far right are a combination indicator/switch. The second one in is the Wi-Fi radio on/off switch. Press and hold for two seconds then release. Your Wi-Fi radios should come back on.
Oh so true.
Too many people miss the bit that the physical switch and the controls are not connected.
