dlchase
Jan 05, 2022Follower
R6400 upgrade
I am planning to upgrade my R6400 router to a newer Netgear router. Is there a way to copy all of the settings in my old router and upload them to a new Netgear wireless router? Using Windows 10 64...
- Jan 05, 2022
No. Backup configuration files from only same model routers can work on other same model routers.
Netgear has set up a community forum specifically for General Router products:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Thank you
Jan 05, 2022Guru - Experienced User
Thank you
