rasweat
Jan 28, 2019Aspirant
R6400 WiFi not working
I get home and my wifi is not working. I check in the manager and there is a big fat yellow warning that my wifi is off. I did some searching and after reading multiple threads about pressing and hol...
- Feb 01, 2019So after I put this post up. I realized that my hard reset did not take. I navigated to hard reset in the software and executed. Th at fixed my issue.
Zycal
Jan 29, 2019Aspirant
Hi,
I am having the same problem; the wifi suddenly failed while watching TV. Tried resetting the router and pressing and holding the wifi button on the front panel, nothing seems to work.
Thankfully, the internet is still on. The wifi light does not blink even when I pressed the button. LEDs pic attached.
Firmware version: V1.0.1.46_1.0.32
Any possibilities to save it?
Thank you
rasweat
Feb 01, 2019Aspirant
- myerswFeb 01, 2019Master
Thanks for the update of what fixed your issue.
Could help others.
Reset does seem to fix lots of problems.
