DannyMac53
Jan 04, 2021Aspirant
R6400v2 — AC1750 Smart WiFi Router 802.11ac Dual Band Gigabit connection problems
I have had the R6400v2 — AC1750 Smart WiFi Router 802.11ac Dual Band Gigabit router for less than six months and it seems that at least once a week I have to unplug and reset the Internet so my Wifi ...
Jan 04, 2021Guru - Experienced User
What modem do you have?
what firmware is on the router?
- DannyMac53Jan 07, 2021AspirantI have a Netgear CM700 cable modem
Firmware version: V1.0.4.106_10.0.80- plemansJan 08, 2021Guru - Experienced User
When it drops, what exactly happens?
Does it say "connected, no internet"?
Does it power off?
Are you able to access the router and the modem when its having issues?
What exactly happens?
- DannyMac53Jan 08, 2021AspirantTo add to my reply, I get a message saying that the wireless devices cannot connect to the internet because there is no connection. Same with my hardwired desktop. The router itself does not shut off
