rlwagency
Nov 17, 2020Follower
R6400v2 - continually cycling off
Purchased in Jan 2020 a Netgear R6400v2 router. For the past month it has started powering off and rebooting. We thought it was the internet and had that checked out. The past 2 days it is a LOT w...
Nov 17, 2020Guru - Experienced User
How frequently is it happening?
How long does it stay off?
What firmware version are you on? The latest isnt always the greatest.
Have you tried a simple factory reset and clean install (not from backup)?
