RJL523
Nov 18, 2020Aspirant
R6400v2 AC1750 download speeds
I purchased this router a few years ago and with several of us working from home have been having internet speed issues. My internet plan is for 200 mbps but I am only getting ~ 90 mbps down and 35 ...
Nov 18, 2020Guru - Experienced User
What firmware version are you on?
What modem/gateway is it connected to?
Have you checked the cable? When you get that 90mbps (ish) it makes me suspect it isn't connected at gigabit speeds. The ethernet cable is a reasonable first place to check
- RJL523Nov 26, 2020Aspirant
Thanks for the reply. Figured out it was the cable connecting the modem to the router. Still not thrilled with wifi speeds but at least I see I'm getting the correct speed to the router.
