RJL523
Nov 18, 2020Aspirant
R6400v2 AC1750 download speeds
I purchased this router a few years ago and with several of us working from home have been having internet speed issues. My internet plan is for 200 mbps but I am only getting ~ 90 mbps down and 35 ...
Nov 18, 2020Guru - Experienced User
What firmware version are you on?
What modem/gateway is it connected to?
Have you checked the cable? When you get that 90mbps (ish) it makes me suspect it isn't connected at gigabit speeds. The ethernet cable is a reasonable first place to check
RJL523
Nov 26, 2020Aspirant
Thanks for the reply. Figured out it was the cable connecting the modem to the router. Still not thrilled with wifi speeds but at least I see I'm getting the correct speed to the router.
