JJhebert
Nov 16, 2021Tutor
R6400v2 AC1750 Smart Router is slowing down my internet speed
My R6400v2 AC1750 Smart Router is slowing down my internet speed, purhchsed in 2019. Firmware Version V1.0.4.120_10.0.91, I confirmed that Spectrum is providing 110 Mbps to my Modem, but speed tes...
JJhebert
Nov 16, 2021Tutor
2.4, ookla , server is on portland maine where I live Using an old ASUS A750 laptop
I use to get 110 mbps on it
Nov 16, 2021Guru - Experienced User
2.4ghz is sensitive to interference. I haven't seen many devices other than AX devices hit 100mbps over 2.4ghz.
My AC systems usually hit around 30mbps sustained with peaks of 60-70mbps.
You can try changing what wifi channels its broadcasting on. try 1-6-11.
Is your work laptop using a vpn?
do you have a different device you can test both wired and the 5ghz off?
- JJhebertNov 16, 2021Tutor
Thanks, I logged into my router, could not find where I change the wifi channel?
I am not using VPN on the 2.4 machine,
plemans wrote:2.4ghz is sensitive to interference. I haven't seen many devices other than AX devices hit 100mbps over 2.4ghz.
- plemansNov 16, 2021Guru - Experienced User
JJhebert wrote:
Thanks, I logged into my router, could not find where I change the wifi channel?----
How do I change the wireless channel on my NETGEAR router? | Answer | NETGEAR Support
I am not using VPN on the 2.4 machine, -----Thanks. Reason I ask is 2.4ghz is slow. And VPN's can slow down connections. Thats why I was checking if there was a different device you could test 5ghz on. As well as if you can test your wired speeds. the wired speeds will determine if the router is functioning as it should.
Hey Hey - i Used 6 and it's now it's over 100 mbps!!! Thanks.
